Has anyone else tried them? That's what I have on mine, but I can't compare then to anything because this is my first. Unless you count my Walmart crawler 10 years ago,with the Baja claws.
did you already trade, from reading online it looks like the RTR krawlers are the harder compound and that they are coming out with an R35 Krawler (red label) that will be much better.
They are hard. I had cut the foams, made a little difference. Now, foams are completely removed and vents are open. They look closer to being aired down now, and they grip/conform a lot better.
Won't be able to make it, I've got mine torn down for all new bearings. Anybody know where I can get copper bushings to replace the ring gear pinion bearings? Pro4 is rough on those things!
Yeah I might need to get some from you. I really haven't had much time mess with it I've been pretty busy between work, wedding stuff and buying a house.
