I started today off by finishing up the novak tcase cable shifter, smooth as butter.
Then looked at the transmission shifter but that brought more questions than answers.
Then I swapped out the spark plugs and installed the driver's side header. It fits well.
Passenger side the collector hits the upper control arm mount.
I notched the collector enough to install it, but I can only notch enough to get maybe 1/16" clearance, not going to work. I've thought of a few options.
1) cut the top of the uca mount and replate it close to the arm joint.
2) another set of ebay headers that dump to the rear and use the passenger side out of that set with driver side I have?
Ideas?
Also, the summit plug wires I got dont look like they're going to work on cylinder #3. Also, I put one on a plug, pulled it right back off, and the connector stayed on the spark plug. Now questioning quality of those wires...
