Tripp and I put in a few hours last night. He worked a little more to get the jeep harness cut down as much as we're going to do before hooking things back up.
Then we wanted to make sure we had a materials list for the cross member, and this is where things went sideways...
The Advance Adapters universal transmission mount 716003 does not fit the 4l60e to 231 adapter. The adapter has threaded holes in the bottom, and the 716003 doesnt have any dimensions listed, so I wrongly assumed it fit... The holes in the cast piece are too far apart. Also, the fancy counter sunk holes were too close together for the transmission mount included in the box...
So, Friday night, AA closed until Monday, no mount. Good thing Tripp has a machine shop.
The threaded holes in my adapter are closer together and didnt allow for a single piece of stock with bolts going both ways like the AA piece. We devised a two piece adapter that one half bolts to case, one half to trans mount, then they bolt together. I have no pictures of this so Tripp will have to post or send them to me.
So with a solid plan around 11:30 last night, we went to bed. This morning I picked up a few more supplies and went to his house to finish the machining.
With the adapter sorted out, we started working on an independent crossmember that can hold everything up with the skid removed. We used 1x2 tube, some 3x3 angle, some nifty threaded bungs in the frame, and again Tripp will have to post pictures. It worked out where it is very close to the skid plate original bolt holes, so we added a plate to the back of the 1x2 that will allow it to bolt into the skid for extra support.
Almost finished product.
![20190720_211222.jpg](https://offroadsc.com/data/attachments/17/17586-c9b78885f9d5b17fcb9a091ca1fc59b1.jpg)
