This AC system has been a learning experience.
Tripp and I realized pretty quickly when looking for fittings that something wasn't right. I was searching on ColdHose and Tripp was looking at Jeepair, and he was like "Where is that company located?" and I was like "Ocala Fl" and he was like whats the address and... To the point, AirParts, ColdHose, and JeepAir are all the same company. With this new found knowledge I called them the next day (technical support is only available 10am - 2pm Mon-Thurs)
Trish at AirParts has been extremely helpful. She set me straight that the vintage air system uses the drier on the high side and I had to use an accumulator like the jeep did from the factory. She gave me some part numbers for GM accumulators with threaded fittings. I ran up to Oreilys and with their interchange got an accumulator. She said the part number was for sae thread accumulator, but what I got from Oreilys was metric threads. Custom hoses so I proceed but I can't find one of the fittings I need in metric. I email Trish again and she says somethings not right, it should be sae. Oreilys orders another one next day thinking wrong part in box (picture is of what I need and doesn't match part). New part is same as first.
Trish says no problem, I have one here. We'll build your hoses and send it. So I use the metric one for mockup and proceed.
I get all my part numbers together again and the condensor end fitting with HPS shows out of stock. She says they can custom make something, no problem.
I just ran through the whole system with her again and I'm about to send off this box. The compressor to condenser hose was close enough to the stock one that I was able to cut and bend for a mock up. I'm also including a coat wire mockup of the accumulator to compressor.
