Crossing over between the regular build thread and the swap thread. I had to pull the winch again (which means bumper too) so I decided to swap the power steering line that got into the crank pulley at some point. The new replacement is shorter for whatever reason, but that's a good thing. Doesn't look like it could get into anything again.
I decided since the power steering reservoir was empty anyway, and I wasn't happy with what I had, I'd go ahead and switch it out. The new tank has the return fitting lower so I don't have to fill it all the way to the top to keep it from aerating.
The threads were pretty shitty on this new tank, and the fitting cross threaded while trying to install in place. I had to pull it out and run to TSC looking for a 9/16 18 die, which of course they didn't have. But they did have a grade 8 nut, so I used that to clean the threads and got it done.
Finished reconnecting the winch and all, but had to quit for dinner before cleaning the fluid off everything and reinstalling the belt.
