Its pretty simple with a rainbird system. Lay the wires with the water pipes, connect it all up, set your zones, and turn it on.
There is another system out there that is even simpler, but has a lot of moving parts. You can set zones near the house where it will reduce pressure to still hit the grass, but miss the house when it turns, and then once it clears its back to full pressure.
