Guzzy Build
I have seen people graft LJ tub back to a YJ tub, the actual tub is the same. You just have to add a belt rail to the top of the tub to make it match a LJ or TJ.
does anyone know what size the tailgate bolts are? instead of cutting the corners out for the tailgate hinges, I plan to space the tailgate hinge off the tailgate the same thickness with some scrap aluminum i trimmed off the corners. I'm trying to find online what bolt pattern the bolts are?
Spent the evening in the garage last night. David was able to almost finish the brake lines and I prepped the tub for raptor liner.
nothing like washing the inside of your jeep at 11pm
Cant wait to see how the raptor liner turns out. You'll have to let us know what pressure you spray at if you can try to get a close up shot to see the finish texture!
