looks good steve. One thing I have seen with my old smoker was with the vents on top like that you cannot smoke stuff in the rain. The lid fills up and pours water on the fire.
I thought about that after I'd drilled 2 of the holes and it started thundering. I'd like to find a lid for it off a grill, or else using the doming dies on the pullmax or eckold to make something.
Do you run a heat diffuser or bowl of water in yours? Saw some plans on the internet concerning both but don't know to much about smoking.
That is true brooks but it doesn't allow the fat to melt through the meat. It will be a lot juicier if it's fat side up. You can use cheap bacon as a shield.
Put it in a roasting pan so you can keep all the fat goodness. Pour it back over the top later
Sent from my SCH-R760X using Tapatalk
cook off at my house?? ill supply pool and fun times, i suck at cooking
Challenge accepted... I even know some certified BBQ judges..
I cooked my loin in a slim tray of tin foil and kept the marinade around it on Memorial day. It was probably the best pork I have ever had. The smoke ring was thin, but a loin isn't really something you want (or I want) with a heavy heavy smoke flavor.
