Finally getting some projects done that I've had for years.
Ugly drum smoker isn't 100% done
I've got another great in my shop in abbeville that I need to put in. Also gonna paint it. Gonna try and smoke something this week or next Saturday I just need to figure out heat control and what not.
Also finally made a stand for my portaband ImageUploadedByTapatalk1402255252.906353.jpg
The table for these things are super nice if you don't have a full size vertical band saw and with a zip tie around the trigger and it being hooked up to a foot switch it's handy.
looks good steve. One thing I have seen with my old smoker was with the vents on top like that you cannot smoke stuff in the rain. The lid fills up and pours water on the fire.
thats a sick line, I want to see someone attempt that. any video from those guys?
Thats an old picture. I talked to the guy that owns it now at the Pickens Jeep Cruise in on Saturday, and I really liked it so I found the build thread on pirate. rnuovrcj5 on here owns it now.
Well... I was trying to install my spartan locker this weekend... it didnt go so well. I was trying to take out the pin that holds the cross pin.... broke a drill bit in one side and a small screwdriver in the other. I tried to drill it out my self and the drill bit turned out to be hardened steel. uploadfromtaptalk1402316398213.jpguploadfromtaptalk1402316415436.jpg
Sent from my SGH-T999L using Tapatalk
Well... I was trying to install my spartan locker this weekend... it didnt go so well. I was trying to take out the pin that holds the cross pin.... broke a drill bit in one side and a small screwdriver in the other. I tried to drill it out my self and the drill bit turned out to be hardened steel. View attachment 5331View attachment 5332
sounds like someone needs to invest in a set of punches. :flipoff2:
http://www.harborfreight.com/5-piece-long-drive-pin-punch-set-93111.html
My cousin is the shop manager at galeana jeep, they are going to drill it out with diamond drill bits
which end of the drill bit did you stick in the carrier? the pointed end or the blunt end? The roll pin only comes out one way, it looks like when you were hammering the screwdriver in, you were trying to drive the roll pin out the wrong side. it should go in and come out the end with the larger hole .
