Started back on the jeep after lunch today and just finished for the day. First I finished up the front end. Had to take a couple pieces off so I could swap some of the stock bolts with the nice button head bolts I got with the kit. The instructions said to use the stock hardware in those places but when I finished I had leftovers so I used them.
Then I added the LED marker lights and turn signals. Changed the blinker to the LED blinker I got from genright. I spent some extra time doing the wiring right. I soldered and heat shrinked all the connections instead of using the little plugs provided.
Then I started on the driver side corner guard. Took a while to get it to fit right by myself. But with some clamps and jacks I got it all done. Tomorrow I should be able to do the other side and get the rear lights installed and wired. Then finish up with the sliders on Tuesday.
