Required Vehicle Equipment
1. Valid Driver's License
2. Fire Extinguisher (1A10BC Dry Chemical) - These are commonly available at any WallMart, Home Depot, Lowes, Sam's, Costco, or other homecenters. Common cost is typically in the $10-20 range depending on size/features.
3. Basic First Aid Kit -- These can commonly be found for $20 or less. The most comprehensive one we've seen is available at Sam's Club for about $20.
4. Tow rope or strap (Note: Straps and ropes with hooks are not acceptable). As a minimum, straps must be 2" wide, rated for 10,000 pounds, and at least 20' in length. In addition to the many fine off-road suppliers, these and other common recovery necessities are commonly available at WalMart and/or Northern Tool.
5. Safety belts (one for each occupant). This is non-negotiable. All individuals must be properly restrained by factory or better equipment (for their own safety) inside any moving vehicle on a club ride.
6. Spare tire, jack, and lug wrench. (Note: The spare tire must be within one inch of the diameter of the vehicle tires. Exceptions are made for vehicles with 38" tires or larger due to weight and physical size.)
7. Front and Rear tow points. These MUST BE FRAME MOUNTED in one manner or another. The hardware is typically available at any off-road supplier or auto-parts store.
