Gulches (pre-Windrock) testing session
01tj
Guest
#86
Marcus, did you find out what was up with your front hub?
The outer shaft on the RCV was rubbing in one spot on the inside of the spindle. I have read where some will require a little clearancing and some wont. I took it apart and did cleaned it up the inside and put it back togather, but it was raining so I didnt get a test drive in. Ill do that after work today.
