The Long way home: YJ Fly and Drive
Fuel Stop · Wed Nov 11, 10:55 AM CST
Posted by Brooks
⛽ 12.98 gallons
Alright, so fuel gauge is for sure not accurate. Half tank is empty… noted. Filled up and filled our new auxiliary tank. 20 miles on trip odometer but with the larger tires… we’ll have to do some calculations
📍 Location on map
Follow the whole trip →
General Update · Wed Nov 11, 12:42 PM CST
Posted by Brooks
A little later than planned, but we are on the road. A few wiring issues fixed, holes taped shut, and now we have a phone mount. Our GPS transponder for the map was hit or miss where we mounted it, remounted it on the dash in hopes of better signal. We’ll see if we can cover some ground on the way toward Alexandria.
📍 Location on map
Mechanical Issue · Wed Nov 11, 1:58 PM CST
Posted by Brooks
Alright, clutch was not clutching, thought the slave went out, no fluid in the master cylinder but turns out that wasn't problem. It helps if the linkage is connected. Fixed it with a new cotter pin and we are on the road!
📍 Location on map
