Alot of work got done today to end up with axle back where it started.
It started off slow trying to swap the yoke. I didn't have the right size socket (1 5/16) so I ran up to TSC and got one in 3/4 drive. I come home and can't find my 1/2 to 3/4 adapter so I call @Twilliamson to see if he had one. He reminds me that I brought him a socket and adapter to remove his pitman arm. Guess what size that was. No problem, now I have one for my truck bag.
Then my impacts (electric or air) wouldn't budge the nut and I couldn't hold the flange. Had to raid the bolt stash for some m8 1.25 and make a spanner.
Then on to removal of broken axle.
And test fit of new axle. This truss is so nice. It was easier to get the bolts in than getting them out of the old axle. I'm going to cut the upper spring mounts out and level them.
Then back out and on stand for much more welding.
I came up and ordered a set of crown extended lines to get the rear. I had one but must have gotten rid of it at some point. And I ordered some brackets that I hope are going to work for the ebrake cables. I have a Metalcloak adjustable trackbar on the way as well so I'm going to finish welding, put it back in for final touches, then out again to paint.
