Twilliamson
I spy Fireball squares...those things are legit... I love our set.
Best money spent!I spy Fireball squares...those things are legit... I love our set.
Oh it definitely needs a swaybar will be putting a TK1 on it. Only a matter of time and money. I’ve also never used a suspension calculator, just also put things where they fit so I’m sure it could be better but it works.I saw mention of a rear swaybar, you still thinking about one, she looks like you get a little torque twist under load on climbs from your pics.
1550 spicer joints. Should be okay but there is always a fuse somewhere!Just be careful on the send pedal when you have that steering ability. Not sure what axle joints you're running but that's the easiest way to send one into the crowd.
Whatever came in the shafts is what is in there likely not full circle clips but I will probably end up tacking the caps in just to be safe. I’ve got to do something because 10 point turning on the trail to turn around or do a 3 point turn just to make an easy right turn ain’t cutting it. Can I buy full circle clips or do I have to buy the whole joint?Full circle clips I assume already in there...
I would be apprehensive with that steering capacity. Just be mindful, it will be fine. Till it ain't.
OSCAR!Well I got my radiator back in today. The bottom mounts were honestly probably enough to hold it in place once all then coolant and trans cooler lines were hooked back up it didn’t move but I wanted to be sure so I whipped these little mounts up for the top that will use hose clamps to keep it from coming up. Need to get some shorter hose clamps but all in all this is going to work out fantastic. Be ready to ride in no time! Who’s up for a gulches day trip?!
View attachment 22722 View attachment 22723 View attachment 22724 View attachment 22725 View attachment 22726 View attachment 22727 View attachment 22728 View attachment 22729
What are the dates for that trip?OSCAR!
