Got the motor freshened up and installed Saturday.
Sunday I put on new rear shock mounts on the axle, as when I rotated my pinion angle down to account for the longer driveshaft it made my mounts to high and caused it to bottom out before the bumpstops hit. Also welded on the new axle tie down brackets on the rear axle. Still need to do the fronts.
Drove it to Batesburg yesterday and @Twilliamson helped me put in my GMRS radio and run the cable. Put some miles on it and it seems to be doing well.
- Front input seal on transmission - still dry, leak was undoubtedly coming from the motor.
- Rear Main Seal - installed
- Front Main Seal - replaced the seal, and installed the new harmonic balancer that I had put on my old 4.0.
- Valve Cover gasket - Installed
- Oil Pan Gasket - installed
- Pilot bearing - installed as this one was from an automatic.
