I started adding fluids to the systems.
Clutch is filled and bled
Brakes are filled and i had to replace the rear wheel cylinders (FJ40 has two cylinders per side) still need to bleed some more, pedal is still soft.
Replaced the spark plugs and wires
This weekend i will put the ECM in and see if it blows up.
I also found my wheels for the Rover
Toyota T100
Old rims
New Rims
Going to look a bit more original... if that is possible with this build
Added some paint today
Now I need to find some 33x12.50x15 tires since the the wheels on the truck are 16".
