I got both axles installed an kind of rolling.
For the rear axle issue i had with the ubolt not fitting over, i did a ubolt eliminator setup on one side and ubolted the other. I do not have the perch welded to the axle, i need to figure out my pinion angles first, but it is under the rig.
Rolled out into the sunlight to compare the wider tires to the original ones and see how far it sits outside of the tub. I am not a huge fan of the rims, but they will have to do for now.
The front axle got pulled out. Bye Bye drum brakes
