Alright got a little done to it. Stripped out the old seats and removed the fuel tank. Got a 12 gallon cell to throw in the back and fittings on the way from Summit. Also got a set of Corbeau Baja JPs on the way. I was torn between Mastercraft Nomads and the Corbeaus but pulled the trigger on the Corbeaus. I need to get the seats mounted up and the cell in and can get back on the trail and not be completely uncomfortable. I do have plans for a completely new cage one day, so I am going to try to make the seat mounts relatively easy to change. The way the previous owner had the stock seats mounted was a PITA to remove.
After this the next two things I have to tackle are a traction bar for the rear axle and get started on a 1.6 swap. Anyone please let me know if you see a cheap wrecked Geo tracker, suzuki sidekick or x90.
