It's been awhile since I updated this. I've been making some changes so I'll bring it up to speed. Last year I was having problems with fuel delivery, since then I put a stock tank back in and that's fixed all those problems so far. I also added a set of trail-gear sliders, the 58" kit fit perfectly. They're welded to the frame and I ended up adding some polyurethane bushings to tie them into the body mounts as well.
Last weekend I started redoing the exhaust, the headers hung below the frame and the muffler hung below the frame so I've been looking for a reason to redo that anyway. Anytime I've ever taken something to an exhaust shop I've never been happy with the results so this time I decided to do it myself. I got a flowmaster hushpower muffler, hedman shorty headers and some mandrel bends and y-pipe from summit and fit it all together. I still have to put it back on after welding and hang the muffler.
While I was doing the exhaust I figured I might as well raise the transfercase up above the frame rails so I can put a flat skid plate on it like all the cool kids. I made an adjustable transmission mount from some 2x2 square tubing. This raised my front driveshaft up quite a bit though so I'm hoping it doesn't come apart when the driver side droops down. I'm still working on the skidplate but it will be 3/16" steel plate I had.
I also got a march performance serpentine belt bracket kit for christmas as my belt would eventually start squealing due to the pulley's not being exactly lined up.
Next up I have some curry johnny joints ready to go in for the bottom links, I'm going to be raising the mounting on the frame and axle as much as I can, eventually.
