Looked at it again when I got home tonight.  The truss is pretty close to being where the balancer is actually.  But, the suspension is drooped most of the way out so it is going to go forward a bit when its at ride height.  Either way I don't think there will be an issue though as there is 10.5" of clearance between the truss and the oilpan/balancer area and only 10" of shaft showing on the ORI.  And the ORI's have a built in bump so it will bottom out a bit before that even at the hardest hit.  I will definitely leave the passengers side tacked in and cycle it some to check things before I burn that side in.  Worst case scenario I will have to shorten the truss on that side.
