Documenting some of the Maintenance I did this weekend here in case I need it in the future.
5-31-2014
Replaced R&P with 4.88 Thick Cut Rubicon Gears with larger than stock Ring Gear Bolts (Clemson 4 Wheel)
New Pinion Bearings and Seal (Clemson 4 Wheel)
New Carrier Bearings and axle seals (Clemson 4 Wheel)
New Lockright Springs and Pins (Clemson 4 Wheel)
New Timkin and National Wheel Bearings and Races (A-35 and A-37) Outers from Autozone in Newberry, Inners from Advance in Chapin
New Wheel Hub Seals (for Ford Hub, not the jeep hub) (advance in Chapin)
New Raybestos Blue Boot Balljoints (Rock Auto)
Note:
driver side inner shaft has yielded splines but Ujoint is good. Long Side Ujoint seems tight on one axis.
Hub Fuse installed on Driver side Hub, Full Warn Premium installed on Passenger side.
202,156 miles
