Ram-Rod
Well car Ram-Rod saw daylight via it's own power again today. Everything is pretty much good. Temp gauge isn't working, gotta fix that. Still have two small exhaust leaks, which are causing it to run sorta rich. Gotta fix that. T-case shifter cables are not adjusted right so it's not wanting to fully engage in some ranges. Should all be easy fixes and then all thats left to do is throw the belly skid under it and load it on the trailer. See you boys in KY.
I'll tell ya what matt, Ram-Rod is looking GOOD!!!
Those colors make it super clean looking. Those bright eeeerrrrnnnggg, and flo green colors need to go back nnnnniiiiiinnnnneeeettteeeeennnnn94 joe diffie coming out ya stereo.
Trans. update after OSCAR II. Broke the pump ears that engage on the converter about 5 hours in. Snapped one clean off and the other looks like it broke after the first snapped. Talked to several transmission places and friends I used to do the drag racing thing with and it's not common, however not uncommon to happen. Waiting to hear a price back from a friend of a friend that built the trans in my Camaro. He is going to look into some upgraded pumps for me and try to get the trans as bullet-proof as possible. The converter is getting sent back for more stall as it was not right to begin with. Hope to be back going by the first of next month. No reason to put it back the way it broke though. I do however have a spare pump and will carry it on long trips from now on.
You not know redneck engrish??? Thast litterally exactly what two guys told me on the phone today. Guess the stupidity stuck in my head. On the other note, the pollen is getting washed off of my truck finally.
Wow, it's been two months already....
Finally got the trans back Tuesday. Put it in this afternoon. Still have to put the t-case in and hook everything up this week. Should be ready by the weekend.
