Copied from my JF build
Well i got a good bit of work done today. Got started working on it tonight. I'm gonna have a good bit more work than intended... I didn't realize I had done so much stuff wrong the first time i did it. I guess you learn as you go... It's also very hard to have a jeep at my height with adequate up travel.
Started the night off by flipping the drag link and tie rod to below the knuckle and high steer arm.
then I cut off the track bar, and tacked it in its new location. This should keep the track bar from hitting the harmonic balancer
You can kinda see what i'm talking about in this picture.
This is where i thought i'd be done doing stuff before setting up travel, but i was looking at everything and turns out i made my truss way too big. I'm going to have to redo a very large portion of it on the passenger side of the diff. As it is now, i have about 3.5 inches between the truss and the oil pan/harmonic balancer. Tomorrow will be filled with cut off wheel fun :thumbsup:
These pictures kinda shows it, but you almost need to be under the jeep to see where its at.
