MCJ Christmas Crawl 2012
WolfGT
That's awesome trip. Great job. I hate that I missed it.
I see that Scott had to back off that rock .... what happened? I assume that is part of the above mentioned carnage. Who's going to post up a breakage report?
#22
There was a snap and a wheel spitting out...
Scott broke a rear shaft on the first ledge of Daniel Saturday. Brian lost his front driveshaft between the ledge and the three line hill climb. He and Cole rock bounced it the rest of the way and got a few pulls from Chase's JK. I think that was the only damage on the trail.
On the way home, Brian had a few issues. Don't know what it turned out to be.
#27
I killed another door... Also bent my 3/16th crossmember a little
The oil pressure sensor on Brian's jeep started leaking on the way home so we stopped and replaced it. We made it another 30 minutes down the road and then his jeep was smoking really bad pulled over and found a trans leak, it appears the torque converter seal started leaking, so then we limped his jeep the rest of the way home
