Been able to get some more crap done on the TJ after finishing 2 classes in the Summer I session and installing the raceline beadlocks and genright tube flares on the JKU.
So this brings me to where I currently sit, and will hopefully be complete within the next week. Especially considering that grad school cranks back up for me on 13 Aug 12, which pretty much blows.
After swapping the genright EXT tank for a RCI 2161A, I went ahead and comp cut the back of the TJ, welded on some 3" tube flares to match the front, installed a modified swap offroad drop down tail gate conversion, reconfigured my drop down rear tire carrier mounts, and a bunch of other misc stuff.
After most of the rear body and fuel system stuff was complete, I went ahead and pulled the front end and took the plasma cutter to it. Removed the TNT truss system, trac bar and mounts, installed the reid knuckles, fit and welded up the new artec truss, bent up some tube for a radiator hoop and winch hoop, and bent up a new coilover hoop cross over bar.
Things left to do this weekend and early next week:
Build new rear upper and lower links
Install new axle side link brackets
Fab front and rear lower coilover mounts and make decision on running either the 12" or 14" foxes in the rear
Remove the rear frame crossmember where the fuel tank used to mount to and retool the rear body mounts that are contained in the crossmember.
Figure out new front trac bar placement and bend up the trac bar as needed
Fab new front upper link
Reinstall hydro ram and decided between the offset or standard TREs on the tie rod, which results from the differences between the reid knuckles that use chevy castings and the factory ford kp knuckles.
Fab up front and rear air bump landing pads
Have Fred retube my rear driveshaft for the 3rd time to add length for the increased stretch.
I'm sure I'm missing some things, but that is the majority of them as of the moment. I'm considering cutting up the floorboard of the tub some more in order to make more clearance for the stak d300, with the hopes of getting it closer to flat in order to cure the clearance issues with the side of the 44re's pan and front driveshaft. Still working with Maxxis to try and get a grassroots sponsorship in order to get a set of comp treps and order another set of racelines to mount them on. Then it will be off for another shake down run to try everything out and fine tune the coilover springs rates and valving. If all goes well I might throw my name in the hat for next years ECORS class B series, but more to follow on that endeavor.
