Finally got a little time this afternoon to try and finish up the repositioned front coilover mounts so I could get the jeep back on 4 tires and move on to some other stuff.
So here is how she sat as of this evening:
Current wheelbase is 108"s, which is with all of the links at the shortest settings. Plan is probably to end up at either 110" or 112" depending on how things fit.
The front was swapped from 14" coilovers to 16" remote resis, while swapping the spring rate from 12" 200/ 14" 250 eibachs to 16" 150/ 16" 200 PAC springs. Went with lighter coil rates after doing to some research on a newer pirate thread on spring rates and how to use the lightest coil possible, while using longer length springs and preload. With the new spring rate in the front i've got 1.25"s of preload with 6.5"s of up travel (9.5" down). Also got my new aluminum crossflow radiator in, as my current radiator is the lowest point on the front of the jeep at the moment.
Tomorrow, if all goes well, will consist of fabbing and mocking up the new front trac bar set up, and also perhaps reworking the rear upper coilover mount since I don't have to worry about tire contact with the new wheels. This will allow me to switch from the current 12" rear coil overs back to the 14" that I had on there originally. Also ordered the remote resi upgrade for which ever set of coil overs I end up with on the rear.
