Have a few things to take care of over the winter that 1000 mostly trail miles have exposed...
-The engine skid needs additional bracing. Came down on it rather hard at Windrock and it bent a little.
-Install new fuse panel for the LS harness. It had the plain jane cheap fuse holders and I had an issue with the fuel pump fuse at Windrock. The fuse holder has gotten loose so it allows the fuse to move and kept popping them. I have a much nicer setup, just need to install.
-INNER FENDERS for the front. I had hoped to cut some myself with my new plasma table but time may force me to order some if stuff doesn't start happening faster around the shop.
-You need a full top for SE wheeling. If you care about your rig at all... I hope to do a top before Harlan this year.
-Still have to pull the front end and body armor apart and clear the tub.
-Would like to go to an ARB compressor that allows for OBA.
-Still want to do an under dash vintage air setup, but that is not really a priority and $$$
My goal is to have everything on this list done less the ARB and Vintage Air before Harlan. Also planning to take the CJ on the Poker Run this year, that is if it happens.
