Parts/Tools list for Moab, whose bringing what?
It was suggested we put together a list of whose bringing what for Moab.
Please maintain a list in your original post if you change things, instead of creating new posts for items you think of.
In Jeep:
-comprehensive tool set (my junkyard box/bag)
-pair of front unit bearings (late TJ) with stubs in them and tube plugs for sleeved dana 30.
-2 front brake lines
-2 1310 ujoints
-1 5-760x joint
-ujoint strap kit
-assortment of TJ axle/driveshaft hardware
-valve stems and stem replacement tools
-tire plug kit
-onboard air
-assortment of 6AN plugs/caps/unions
-ARB line
-general electrical
-fluids
In Trailer:
-front driveshaft
-complete TJ steering (draglink, tie rod, ends)
-set of assembled stock dana 30 shafts
-set of rear dana 44 shafts
-fluids
-ball joint press kit
Can bring but not decided:
-hi lift
-cordless tools
Trail tool kit
Drivers Drop front Waggy Driver and passenger shafts (Assembled)
1-760x joints
Driveshaft hardware for d44 and ford 8.8
Dana 44 balljoint spanner
Dana 44 Hub Socket
Warn Premium Hubs
ARB Airline
Fluids
  • Trail Tool Bad
  • Wiring and Electrical Parts + Fuses + Relays
  • 1- Used ?1310? U Joint
  • Hi Lift
  • Cordless impact w/SAE Sockets
  • TJ AC Delete Belt
  • CPS Sensor
  • Fluids (Bag of Gear Oil, Quart of Oil)
  • Hardware Assortment
What should I bring cordless tool related? I figured I'd throw the impact in the truck. Could bring grinder, sawzall, drill, etc...
Sawzall could be useful.
Tools I’ll have:
60” Hi-Lift
Drill and Impact
1/2” impact
Socket set
Grease gun
All fluids I run
Grinder and accessories
Electrical components and tools
Parts I’ll have:
60F shafts
1350 driveshaft parts and enough shaft to build a front if needed.
1350 joint
1350 u-bolts
Various heims and misalignments
1-1/4 RH Johnny Joint
Bolts that fit my junk
Spare 39” Krawler on a steel wheel. Thanks @VOLT
Trail tool kit
1-760x joints
Dana 44 Hub Socket
Warn Premium Hubs
ARB Airline
Fluids
I have a spare rear driveshaft but I didnt have a chance to get it lengthened. So we can make it happen out there if needed, i'll bring the stubby.
Ive got a cv axle, inner and outer tie rod end, wheel hub assembly, and some spare air filters. Otherwise she should be about ready. Ill program my crawl control stuff tonight.
