Mikan the Samurai
I’ve been looking for a small utility vehicle for around the house for a few years. Originally I was set on a Honda FourTrax 300 since that’s what I grew up with, I wanted something reliable, simple, and cheap to work on.
A few years ago I started looking at kei trucks with dump beds, but the prices kept me away. Most titled ones seemed to be $7k+, and I wanted something small enough for our trails but without a CVT like a lot of modern SxSs (too loud for what I wanted).
Last fall I started watching for a Suzuki Samurai on Facebook Marketplace. Samurais are all over the place, $500 rust buckets to $20k period-correct builds. I wanted something closer to the low end but with minimal rust and not heavily modified.
I found Mikan in Georgia before our Alaska trip in April, but it was more than I wanted to spend. In June I reached back out since it had been listed for a while and asked if they’d sell just the Samurai instead of the whole package with the parts rig and extra Sammy parts. They agreed.
So last Sunday Larry, Chris, and I headed to Georgia to check it out. One test drive later and Mikan came home.
#2
Specs from what I've gathered:
Rebuilt 1.3 with Weber Carb
Full cage
body off rebuild with bedliner and paint
Rust free frame and body
Spring Over lift
Cross over steering with high steer arm
Tcase bushing delete (aluminum pucks)
Low mile axles
aftermarket seats
Things I would like to do:
1. Carb adjustments, or maybe a toyota 3k carb swap? I've read you need a fuel pressure regulator with a weber carb, and maybe thats whats causing my flooding and rich idle. There is no regulator between the mechanical fuel pump and the weber. Sounds like webers like between 2-3psi, but the factory mech fuel pump is around 4psi.
2. check full steering limits, the custom high steer arm installed seems to be limiting full steering lock, but I need to check, the tires may be on the stops.
3. lower gears, this may get better if I can get it running better, but lower gears would be great.
4. tcase cradle possibly, if I put in new tcase gears.
5. Front and rear bumpers, to save the body if anyone hits a tree back in the woods.
6. Need to add a back seat, maybe a jeep seat?
7. Tires, the size is fine, but the 235x70x15 tires on it now are old. They seem to be holding air, but they are past their prime and I don't trust them on the road.
8. Put the dash back together, when they reassembled the body and cage, the computer and a few other things need to be bolted back down under the dash.
#3
After messing with the weber a few times, i just bought a toyota 3k carb to try to get better low rpm performance. We'll see how it does. Need to figure out an air filter setup, looking for a stock sammy air box and tube.
#7
found an air box from a guy parting a sammy out in Lexington...... discussed price, got all his details then he sent his address to meet up that night....it was Lexington, NC! Just so happened I was headed to VA this past weekend for our anniversary trip and his house was about 10 min out of the way. So met up and snagged it.
#9
interestingly enough, while searching for the carb info, I found that the 80s model sammys had plastic flares, but somehow mine has metal flares. which is 91 and up? guess they swapped them on in the last 36 years. I'm trying to figure out how all of the computers mount behind the dash, they are both just flopping back there. I think one is an ECU, and one is for the A/C.
I'd say check Frank but he ain't got no computers.
