While your at it, have a lighter lit at his ***....I'm sure as he gets jolted he'll at least let a massive fart loose...shock ans awe for the viewers at home...hahaha
Marcus, its all yours for a small fee. It'll come with everything you need.
Update: Changed cps last night as well as checked spark. Its getting spark and the sensor did nothing. Still wont start. I'm down to the injectors must not be firing. So what tells the injectors to fire? What sensors would control that?
Have you checked all your fuses? Mine has blown 1 or 2 particular fuses twice leaving it not starting but everything sounded like it was suppose to. Fuel pump might not have primed though, and I even replaced it, twice cause one was faulty.
As dumb as this is, i honestly haven't checked any fuses. And if i recall correctly, theres a fuse that is an "engine control" fuse. Looks like ill be pulling fuses later this evening. Crossing fingers.
