Gladiator
#5
Well it’s time for lift wheels and tires. Definitely going with 37s. Should I stay with factory wheels or aftermarket? Kinda thinking of putting the factory wheels and tires on my XJ. I need help making this decision.
I like the wheels, but I could see wanting a little more offset. Does the JL need more offset to clear suspension with a 37x12.50?
It would take quite a bit to put those on the xj wouldn't it?
#7
What did it come with tire size? Are the rims 17" or bigger?
I think the Falkens that Taylor is running on the Bronco would be a good option. Of it were mine it would probably be between those and KO2s (in the 35" flavor)
How will putting 37s on this affect the warranty?
#10
Uuuuh? Now I’m even more confused. I do want a little more offset for stance purposes but don’t want to sacrifice off road abilities. The XJ is getting a little more lift and some cutout flares so I think I can make it work. Lot to think about including the budget. It’s happening soon tho.
#12
Basically on warranty FCA looks at what caused the break or damage. Did lifting said jeep cause the auto to fail? That is how it was explained to me from a FCA Mechanic.
#15
The falkens are what he has on it now, those in a 37 flavor on stock wheels would be pretty sweet. May need a 1.5" wheel spacer.
#16
I let the guy talk me into the Coopers. Looks like a pretty good tire. I’m puttin them on 17” KMC XD wheels with a -13 offset. Doing a 2.5” lift. There was a identical truck at Golden Motors when I was ordering my stuff with about the same set up except for 20” wheels. It was going to Galeana.
