The tune right now is decent, the major problem is that it seems to be dipping into the idle timing values while it should be in cruise values. This is causing some hesitation under low rpm, high load, like in overdrive. I think I just need to open up the table and see where things are set, Holley has a software for that, that you just download your calibration into, make your changes and then reupload to the ecu. It's also running a bit rich but I think fixing the timing will get me closer on that as well. But overall I've put 500 miles or so on it without major issue. I mostly just want to get a front bumper on it before I take it off-road. I have a couple more things I want to do before Oscar like a CB and a mount for the cooler but those are lower priority right now
