Well after the sickness i got from Vegas I really didnt have any ambition to work on the Flatty. I would come out and clean around it, and sometimes just scrape off some undercoating. Finally i went out and did some work.
The original owner did some body work and not that well, i cut it out and added new rockers, there is some batch patching still in front of it, but it is solid and i will probably try to sand and level it out with filler unfortuantely, but it is not a show jeep.
So rockers are liberated.
Patched spotted in
The original owner put some plate for the rockers with no bend on the bottom like the original panels, I added metal with a bend so it will not slice your hand if you grab it. I need to cut out a drain hole on the passenger side to match the driver side.
Next on the plate is repair the center hump and then put the floors back in.
Patched spotted in
