It did have a tailgate at one time. When I was little, I remember helping him do a bunch of rust repair. He removed the tailgate and closed it in at that time. Also you will see in the pictures to come that he patched the sides under the door openings and fabricated new steps. But even after that work was finished, it never ran.
Something that is neat is that it has a wood deck in the rear. That was put there by my grandpa way back. He did a really good job because even to this day, it is solid. He coated the underside with some sort of tar to protect the wood.
I think I'm going to start from the ground up. Work on the axles, then the trans and transfer case, then the engine, then wiring. At that point, I would just like to run it as is. Then later get a new tub for it.
