That's much better, but what they were saying is that it needs something to keep it from ripping itself off over time. With it not being welded but on the sides, it will let it rock back and forth over time the welds will give way.
On mine, I didn't have enough room to tie it into the diff cover or the cover. I plug welded it in two spots on top of the diff and also welded it in the front and back.
When you get it under there, if there is room I would try to weld a tab on the diff cover and tie it into the truss.
