1987 Suzuki Samurai JX $7,000
Have clean title, currently tagged and insured.
Drivetrain:
-1.6 16V Sidekick engine. Motor was a low mileage replacement into the Sidekick I pulled it from.
-Zuks Off Road (ZOR) wiring harness
-Petroworks 16V swap kit
-Resurfaced Samurai flywheel
-Petroworks clutch and pressure plate
-Samurai 5-speed trans
-4.9:1 samurai tcase in ZOR Slutty Snatch with Panty Liner
-2" exhaust with flowmaster 40, sounds great, revs quick, plenty of power
-Carolina driveline shafts front and rear (front is CV)
Front Axle:
-76-79 J10 Dana44 with 5.89 gears and full spool
-Solid diff cover
-high steer w DOM drag link and tie rod with heims
-complete Trail Gear hydro assist kit (pump to ram) with 8" stroke ram.
-stock shafts with new Spicer joints
-Warn Premium hubs
-Full Traction 0" lift full military wrap YJ springs
-12" pro comp shocks
Rear Axle:
-76-79 offset Dana44 with 5.89 gears and full spool, 1" spacers to match front width
-BTF diff cover
-4 linked
-Currie Johnny Joints on all links
-2" 1/4 wall lowers and 1.75" 1/8 wall uppers I believe
-BTF truss
-progressive rate soft coils
-14" Bilstein 5150s
-disk brakes
Wheels/Tires:
-35x12.50x15 XTerrains, better than half tread
-non-DIY steel 32 bolt beadlocks (probably Allied or Crager)
-spare new 35" XTerrain on non-beadlock wheel
Other:
-6 point cage
-sliders
-tube front bumper with integrated winch mount
-ZOR rear bumper with tire carrier
-smitty 8000 lb winch with synthetic rope and in-cab controls
-RCI2161A fuel cell in bed to make room for rear axle
-E2000 fuel pump
-suspension seats
-Cobra 75 CB
-Safari top
I bought this in 2009 as a perfect, rust free Samurai with Dana 44s stuck under it. It had changed hands a couple times
without the title being transfered over a couple of months, so when I got it I contacted the original owner. It was his
daily driver from '87 to '95. In '95 he had the transmission and tcase rebuilt by a dealer and it was driven 1,000 miles
from that time until he sold it in '09. So technically its only two owner...
The body is still in good shape. It has a few dents but nothing major. The only body issue is we never cleaned up the
trimming for the rear tires.
The only mechanical issue I know of is the right rear axle seal leaks slightly, but not enough to worry about.
It needs nothing and is ready to wheel, just looking to go another direction with my LJ.
Extras that will come with:
-2 complete sets of stock front shafts
-long side rear shaft and a short side that could be cut and resplined to the correct length
-spare set of J10 housings could go with
-full soft top, white Bestop
-spare front Carolina Driveline driveshaft (not CV, works fine but vibrates at speed)
-spare rear driveshaft (don't know brand, was in it when I got it)
-could probably dig up a spare intermediate shaft also
-Replacement set of Petroworks motor mounts
Build thread here:
http://www.offroadsc.com/showthread.php?432-The-First-Samurai
Drivetrain:
Front Axle:
-Solid diff cover
-Warn Premium hubs
Rear Axle:
-BTF diff cover
-4 linked
-BTF truss
-14" Bilstein 5150s
-disk brakes
Wheels/Tires:
Other:
-6 point cage
-sliders
-E2000 fuel pump
-suspension seats
-Cobra 75 CB
-Safari top
Build thread here:
