yeah. me and ronnie will be in the crawler comp, dont think anyone else from clemson is entering. not sure what the classes are (limitations, etc...)
As far as classes go...I think it will be easiest to keep it all 2.2. If anyone brings a different class rig they can definitely run it on the rocks, but the competition will be strictly 2.2.
2.3 - Class 2 – Class 2.2:
▪ 2.3.1 - Vehicle wheelbase is limited to a maximum of 12.5 inches.
▪ 2.3.2 - Vehicle track width is limited to a maximum of 12.5 inches. This is determined by measuring
the bottom of the outer most edge of the front and rear tires while the vehicle is sitting on level ground.
▪ 2.3.3 - Vehicle is limited to 2.2 inch wheels/rims or smaller at the bead surface. Wheels may be modified provided
that the tire bead surface does not exceed 2.2 inches in diameter. With a tire mounted no exterior component of the
wheel including but not limited to the bead lock ring shall exceed 2.55". Tires may be modified from other sized tires
using only a pliable rubber but must not exceed a total uncompressed outer diameter of 6 inches.
▪ 2.3.4 - Vehicles are limited to 2-wheel steering only.
▪ 2.3.5 - 2.2 Crawler class bodiless 8" overall length, 3" overall width, and 3.75" overall height.
▪ 2.3.6 - Bodied vehicles must be 3” minimum height on sides. No less than 12.5”
total length and full original width, and no less than 5” in center.
If you want to read over the rules visit:
http://www.usrcca.com/rules/USRCCA_2011_Final-01-15-2011.pdf
We will go over the rules for the points system prior to starting the comp.
