True but it sees a whole lot more of it. No way I would run 1.25 .120 on a panhard in a wheeling rig. 1.75, maybe but it would be tough to get something that big to fit.
A 3/4x3/4 rod end is rated at 28,081 pounds and the 1.5x.120 DOM is rated at 36,416 lb.
So the chromo rod end will fail before your DOM does. With a rod end on each end it truly cant even feel any other loads but tension and compression.
This is way off topic, and my jeep has .25 wall for everything, but If I were to do it again, I would probably use 1.75x.120 for my uppers and 1.5x.120 for my track bar.
