The driveshafts should be ready tomorrow. With Harry not being there it took a little while to get on the same page but I believe we finally got there. They are building a new rear and re-tubing the front and adding a 1330 yoke. I was wrong earlier in the thread when I thought that my axles had 1350 yokes. I wanted to get rid of the conversion joints that I was running and I think the 1330's will be fine.
I am going to have to begin installing my shock towers and tabs without the shocks being here. I am only going to tack everything with hopes that when the shocks arrive, everything works out(yea right). I will get the compressed and extended lengths from ORIs website to figure placement and with the ride height being controlled simply by nitrogen pressure adjustment I should be able to adjust accordingly if need be, right? I was hoping someone could advise me as to whether I should mock up the towers at ride height or full bump? Hell, I guess I will need to just take a look at them in both positions to see if the angle changes. Either way I want to add another 1.5-2" of shaft so that I can go that much lower in the future when I have a real fuel cell and can notch the floor where the truss hits. The shocks are setup 5.5 up and 8.5 droop.
