Installed a new radio today.
I'm really happy with the way it turned out. I think it's the most 'factory' looking install kit I've seen. The radio actually goes in from the back and screws to the dash piece. It doesn't use the face trim that comes with the radio or the metal sleeve that you usually mount a radio with. This radio also had the cd slot in the front instead of fold down face, so the face plate can be screwed to the radio.
It has bluetooth calling and audio streaming. The audio streaming is pretty cool for Pandora. The calling will probably be pretty much useless in a soft top Jeep, but it does display caller ID on the radio and tells you if you have a text message, so that should eliminate missed calls from not hearing it ring.
