It being a limited slip, his locker choices are limited to full carrier replacements (is there still a lockrite for the ls carrier?). I'd run the LS and see how you like it.
Yeah, deff. atleast give it a shot as it sits. If it's too loose then do a locker. If it's tight enough you may find it works really well. I think Jimbo's did great in his TJ from what I saw.
I bought a swap kit from iron rock offroad I thought was good quality and good price. May also check out eastcoastgearsupply for brackets and I know they sell adapter and brake cables.
this kit makes it super easy to do the swap if you haven't seen it. Its about $70 more than a traditional kit but it leaves most of the guesswork and measuring out of it.
and you should be able to run your current driveshaft with the 8.8 flange on it. Carolina Driveline can get you the flange, or you can get them from a pull a part off a ranger, or I think Clemson 4wheel even stocks them for around $30.
for breaklines all you really need is two of the passenger side explorer lines and two pieces of hardline.
but looking at the kit you mentioned, that is a pretty good deal considering you dont have to go chasing down parts at autozone. I would go with that kit. And now that you mention it, I may be redoing my brakelines too, finally clean up the crappy brake job I did 6 years ago.
nice, this should be a pretty straight forward swap. The only thing you may need if you dont have them already is some adjustable upper control arms to dial in your pinion angle.
Got my parts from ECG today, man that was fast. I just ordered them Tues. hope the rest come in soon. I'm ready to put it back together while I'm off work.
This might be a stupid question, but is it ok for the drive shaft flange to be off center on the 8.8? This might be a more stupid question but do I have the axle right side up on the photo?
The abs sensor and fill plug are in the top so it looks like you've got it the right way. The pinion is offset slightly but that shouldn't be an issue.
