Bought these off a guy on craiglist, thought they might look ok on my XJ. In the end I decide they were a little too big, and would probably require ~35" tires to look proportional. I was going to use them for Highway tires as an extra set. My loss is your gain.
They came off a 2006 dodge charger. 3 of them have tire pressure sensors that would work with 06-07 chargers. New they retail for $50-$100, do if you don't need them you can sell them.
The rims are 18", aluminum alloy, don't know the backspacing but it is probably about the same as stock xj rims. They are 5x113mm = 5x4.5".
There is some curb rash on two rims, the other two are perfect. All 4 hold air. There is some corrosion around the center caps. All 4 have dodge logo center caps.
Located in Anderson SC. Will meet within 30 minutes. Asking $375 for all 4.
Pictures when I get home. Photobucket is acting up.
