I was planning on using the Raptor liner I used on my TJ tub....how does the Armadillo Liner compare in price and quality?
Sorry, took so long to reply. Any 2 part urathane based bedliner system that mixes at the tip will be better than the off the shelf/do it yourself ones that come premixed. Having said that, most all of the brands are urethane based. Armadillo liner has a bit more of a gripp to it than rhino and a little bit more than Linex. Having said that, I'm not gonna sit here and pick apart one brand against another because to be honest, they are all almost about the same base chemicals and they tweak a few specific ones between all the different brands. Bedliners is much like auto body work, there is a somewhat of a factor of what quality of paint/bedliner you use but the biggest determining factor of how well a bed comes out on a truck or whatever your are spraying is your prep work. You can have the best bedliner product (but if you don't prep/scuff and clean well) its all to waste.
Having said all that, I really do like the armadillo liner specifically inside jeeps and trailers because it does have a grip factor to it and helps stuff from sliding around a bit more than the other brands.
I'll throw this into the discussion while we are at it. Many people have a misconception about a jeep and spraying it with bedliner. The misconception is that it is a lot smaller surface area/more compact than a truck bed and therefore should cost less. Not true on several fronts. I'll be flat honest, spraying a jeep is just not fun compared to a truck. It takes about 3 times as long to do everything.
a. you have to remove everything from the interior - seats, seat belts, console, brackets and yes the rollbar (will get on my soap box about that later)
b. clean/scuff - angles/cracks/crevices are much harder to clean and prep than an open surface area like a truck.
c. taping up - the tub lines on the door openings, and covering the dash etc are much more time consuming than a straight line down the bedrail of a jeep - taping up/plugging all threaded seat holes etc
d. angling the gun while you are spraying to ensure you get coverage in all the angles/cracks/crevices is much more challenging than a open truck bed
e. spraying - it seems like a small amount of surface area but its really not when you account for the angles and all the seams you have to make sure there is coverage in all needed places
f. reassembly - reinstalling the seats, seat belts, carpet, console etc
Brooks Pm'd you a quote for the trailer..
Let us know if you got any other questions..
