Ford High Pinion King Pin 60 Front/14 Bolt 5:38's/And more good stuff you need
matth_85
I have a King Pin High Pinion Ford Dana 60. Driver drop. Missing lockouts, but complete other than that. I do not know gear ratio but can probably look this weekend if there is interest. SOLD
14 Bolt rear. 5:38 gears. No brakes. Everything else is there. Came with my buggy project but I didn't want to buy gears for my front b/c I have several spare sets for my 60. Sold
14 Bolt Pinion Gaurd. SOLD
Dana 60 Diff cover from Ballistic Fab 3/8 thick and will actually get it if you buy it from me....hahaha. SOLD Will need a little clean up before you mount it.
Toyota/Dana 44 hybird. Has Toyota center chunk (don't know ratio). Chromoly shafts. Missing a stub shaft I believe. Now selling in parts
2 33x14.50x15 Super Swamper SX's on 15" steel wheels. Tires have fair tread but a little old and have some dry rot. $100
37x13.5x17 Irok. 25% tread. Belonged to Volt so it's gotta be worth somethin SOLD
285/75/16 Master Craft M/T with 30-40% tread. Donated to the Reynolds
Toyota 4runner tailgate with glass. Good shape and everyting should work inside. Glass is good. Motor may be. It was never hooked up in mine. $75 OBO
Will be adding more stuff as it comes to mind and will try to post up pics this weekend.
B&M Shifter rachet shifter. Missing plate that mounts inside the box to show gear selection. Has a good cable on it. $85
Jamar dual master cylinder brake pedal. SOLD
(2) Flowmaster 40 series mufflers. 2.5" inlets 3" out. $50 ea. $90 for both.
Another Flowmaster 40 series. 2.5" in. 3" out. $50 for it also (it's my brothers)
More pics on down.
I have no idea whats in it boss other than the gears. I am gonna pop the cover this weekend. Prob the factory stuff if its a CUCV, but I honestly have no idea. I unloaded it a month or so ago and was gonna keep it till I decided on my plans for my unit.
14 Bolt sold. Thanks JR. I will spend your money on hookers and booze. I am a true American.
No seriously...it will prob all be spent on bearings....damnit
