We have some Rampage Frameless/bowless soft tops in black for 2004-2006 LJs. These use your factory door surrounds and fit around your rollbar and do NOT have a frame. Black in color with tinted windows. The boxes and tops themselves had some "water damage" and they are not in original boxes. The tops themselves are in fairly good condtion but the corners of them and the tissue that seperates the windows etc might have some mildew on them. We have taken one and it cleaned up fine.
You will need a no drill style TJ header bar to install and we do carry and can add those for $45.
These are great if you run your bikini and/or Spiderwebshade a lot.
Additionally, a special note, you can use these with a GR8TOPS JeepJacket because they fit around the rollbar like the JeepJacket does. You can not use a JeepJacket over the top of a factory framed softop and must retract to use.
Here is the PDF install instructions.
http://rampageproducts.com/instructions/tops/109535-top-VER2.pdf
Retail around $700 - Amazon Selling them for around $350
$200 + approximately $25 -$30 shipping.
Add $45 for the no drill header bar.
LJ ONLY.. do not have them for TJ's.
no returns or exchanges on these since they are garage sale items.
Can pick up here in Lexington or we can ship them. Check your shipping if you add to your shopping cart. Here is the item.
http://gr8tops.com/shop/jeepmodels/wrangler-lj-2/rampage-lj-frameless-softop-scratch-n-dent
