Neat Electronics for Custom Builds
Twilliamson
The purpose of this thread is to post up neat Electrical components you run across. Products for your buggy, boat or DD, A place to show off components others might use. Examples: Switch Panels, Power distribution, wiring management .. or even a new Tool you use for working on wiring.
Blue Sea - Dual USB Charger Socket
Ran across this. I absolutely despise cigarette lighter cords. This guy also has enough charge current for you apple fan boys to charge your iPad.
Dual USB Charger Socket2 USB ports w/watertight capFeatures: Watertight cap Corrosion resistant materials Protected from overheating Easy installationSpecifications: USB: 2.0 Input Voltage: 12V-24V DC Output Voltage: 5V DC 5% Max. Output Current: 2.1A DC Cut Out Dimensions: 1-3/16" Dia. FCC Part 15: Subpart B Compliant
Amazon ~ 20$
http://www.amazon.com/s/ref=nb_sb_n...&field-keywords=Blue-Sea-Dual-Charger-Socket/
Harbor freight had a sweet led flood light. It only draws 120vac 4.5watts. You could add some serious amount of light to anything you can dream up, and use a very small inverter to do it!
http://www.harborfreight.com/45-bulb-led-work-light-66308.html
http://www.harborfreight.com/200-watt-continuous-power-inverter-66967.html
I'm thinking of adding 4 of them to the front of my boat on a removable rack for bow fishing.
It's not a halogen, and is suited for 8-10ft area. Not a focused beam, but for lighting up a camp site, under the Jeep wrenching, or for emergencies is great!
I have one of those work lights, and it pretty much sucks. If they made the surface where the LEDs mount reflective it would probably help, but overall it's pretty terrible IMO. Not as bright as my 13w fluorescent work light.
