Don't have this happen to you!
GenRight Off-Road has designed the ultimate tire carrier that fits up to a 42" tire, and is lockable to safeguard your expensive tire investment. The GenRight Tire Carrier relocates your tire from the rear door in order to prevent door damage from the stock carrier under off-road conditions. This tire carrier is sleek, simple and made of super light weight 6061-T6 Aluminum alloy.
This tire carrier is designed to be completely independent of the rear bumper.
FEATURES:
Giant 1-3/4" diameter Aluminum alloy tubing.
4 point mounting is rattle free.
Works independent from the rear bumper.
Swing out tube style design.
Mounts to factory rear door hinges.
100% TIG welded Aluminum (as pictured)!
Designed to hold up to a 42" tire.
Fits any bolt pattern or wheel offset (not stock).
Corrosion resistant.
Fits tighter to the rear tailgate than other swing out tire carriers.
Improves departure angle.
License plate re-location mount.
Cover for factory license plate location.
Pre-drilled for license plate and 3rd brake light wiring.
Made in USA!
Note: We also have tubular mount kits for your hi-lifts and other accessories.
Discuss sales specials with our GenRight Dealers here on the forum. If you call direct, be sure to mention you are a forum member.
FEATURES:
Made in USA!
