Dana 30 parts/axle
So I took out the turdy for good. The axle has no ring gear or inner shafts in it now but does have unit bearings and stubs and I have 2 carriers laying around, also have a short side inner so thats a complete shaft for that side. It has 1.25" wheel spacers, rugged ridge steering (some tre's probably need to be replaced) and a press in johnny joint on the driver side. I also recently replaced the ball joints so those might be good spares.
If you want it all Id let the whole axle go with all these parts for real cheap (If you showed up with $100 you can have it). If people want something individually Id be happy to sell you something. The press in johnny though is still pressed in, and if you want that I need to see about getting it out without tearing it up.
Ill take a picture of it tomorrow.
Sounds good Jake, I got it out. How does $30 shipped sound? Normally they are $55 new. Only thing is you can see in the picture that the inner oring is slightly torn. I can't hardly move the joint with my hand so it still good.
Rugged Ridge steering - new tie rod design on the passenger side. The passenger tre and pitman arm end are pretty loose. They have no "in and out" play but they move freely from side to side with little resistance. Might need some ends replaced. Tie rod has a slight bend in it, its high clearance :grinpimp: $50 picked up for it, just need it gone! Its $270 new.
you can see the bend here
5x4.5 1.25" wheel spacers. For some reason the studs that are in the spacers run a metric lug nut (has the size engraved on the spacer). I have 4 for each, missing the 5th. I will throw in the 1/2" lug nuts too that you need to bolt them to the jeep. $30 picked up, $40 shipped.
Bar pin eliminators - $15, will throw in a flat rate box for $20
Also have 2 good unit bearings with stub shafts in them, $25 a piece.
