Hey everyone, I'm still having problems with my truck. I replaced the tranny, and bought a brand new clutch kit, I put everything together, bled the clutch several times. The truck will shift gears fine when the engine isn't running, so the tranny is fine, when I put it in first or reverse, push the clutch pedal, and turn the key it will starter crawl, which it shouldn't, and it will starter crawl when I use the clutch start cancel without pushing in the clutch pedal. Anyways, when the engine is running and I press in the clutch and try to shift into any gears, it won't shift into any gears, It will idle down a little with no grinding when I try to put it into 1-5, and grinds when I try to put it in Rev. The only thing I can think for it to possibly be is the slave cylinder, the master is putting plenty of pressure when we were bleeding the clutch lines, the slave cylinder travels around an inch when the pedal is pressed. ANY ADVICE WOULD BE APPRECIATED, Thanks!
